It is currently Fri Jul 18, 2025 11:15 pm
PostPosted: Fri Jun 20, 2014 5:54 pm
First name: James
State: Maine
What I want to do is in theory quite simple. But I'm a bit unsure how to execute it.
I want to use a simple preamp with piezo system such as this: http://www.amazon.com/Belcat-UK-400T-Uk ... cat+uk400t
along have a typical electric guitar pickup.
I want to have a selector switch or blend knob that can select back and forth between these two systems.
Any tips for me?
PostPosted: Sat Jun 21, 2014 12:25 pm
First name: James
State: Maine
Perhaps I need to use something like this?
http://www.musiciansfriend.com/accessor ... tads-plaid^57303561547-sku^303128000000000@ADL4MF-adType^PLA-device^c-adid^30423132507
PostPosted: Sat Jun 21, 2014 12:38 pm
First name: James
State: Maine
All I want to do is have an electric guitar pickup (standard design with magnetic pole pieces) alongside an undersaddle peizo pickup and be able to switch back and forth between the two with a blend knob or selector switch.
Or alternatively, simply have each on all the time and just have 2 volume knobs - one for each pickup.
I am open to any way to make such a setup happen and am coming up short on tips and write ups online. Any suggestions would be awesome.
PostPosted: Tue Aug 05, 2014 8:54 pm
First name: Isaac
Last Name: Im
City: Chatham
State: NJ
Zip/Postal Code: 07928
two volume knobs are known to be... fussy. don't ask me why
Who cares about tone if you can look hardcore?
PostPosted: Tue Aug 05, 2014 10:10 pm
I built this guitar many years ago pretty much as you describe. I used an transducer on the underside of the sound board, it was originally designed for a medical application I believe and it had enough output to use as is and ran it straight to the jack, the a couple of pickups and a volume knob of each of the pick ups. No selector switch, just turn the volume off but the transducer was always in the mix. This design was my customers, not mine. It seems to work pretty well.
PostPosted: Wed Aug 06, 2014 12:15 pm
First name: Rodger
Last Name: Knox
City: Baltimore
Zip/Postal Code: 21234
You could use something like the schematic in the attached .pdf
MIMFmag.pdf
Here a shot of one I built.
